Thread: front fender
Created on: 03/01/09 10:52 PM
front fender
03/01/09 10:52 PM
Hey all-hope everyone's safe and sound! Thought I'd share a possible issue with the front fender.I would say every once in a while check your front fender mount area-especially the connection where she mounts up to the vertical bracket to the rear of the fork tube(on both sides).I recently was cleaning my front wheel and happened to look at the fender there-the plastic had cracked and separated from the mounting bolt,and also created an approximately 2" vertical crack upwards towards the top of the fender.The place where it was separated had pulled inward about 1/2".I can only think this was caused by incorrect tightening of the mount bolt(too tight probably)I had tightened it myself a while back(both actually) not thinking that I may be stressing the plastic under the bolt fastener(the metal eyelet).I remember while riding a while back that I heard a LOUD POP,but brushed it off as a rock or something.You guys might want to check your torque settings on those.Stay safe all-have fun!!
RE: front fender
06/22/10 10:30 PM
Thanks Blue. I have lost a couple of these bolts. I tightened them up good but perhaps I will put them in looser along with a squirt of locktight.
scottjkyl
scottjkyl's Gravatar
RE: front fender
06/23/10 2:47 PM
thanks for the heads up there Blue
RE: front fender
06/23/10 4:20 PM
All good....be careful out there...have FUN!!!!!
privateer's Gravatar
RE: front fender
06/23/10 5:12 PM
A suggestion... I had to do this when I mounted my carbon fiber ZX10 front fender with Dubious' brackets....
I put 2 white plastic washers between each side of the fender and the bracket on that side. So when I snugged it up, it only creaked a little. You might need only one per bolt. Each one is different.
Living the Gypsy Life
heathun
heathun's Gravatar
RE: front fender
06/25/10 5:44 PM
I always try not to overtighten various fasteners and use blue loctite to insure they don't back out. For those not aware never use loctite on the body fasteners with the rubber grommets.
RE: front fender
06/25/10 10:06 PM
Hi Heathun!!!!How's everything?Getting some good rides in I hope.We've some lively threads going on here...wanna chime in?
RE: front fender
06/25/10 10:07 PM
In my experience with my 14, the rubber wellnut fasteners do not come lose if they are tightened just enough to squeeze the rubber a bit. The fasteners that come loose are the ones that do not have well nuts. The bottom two fasteners on the lowers come loose. I've lost a couple of those. never had a wellnut come loose. They are designed to resist vibration and to be removed over and over without getting damaged. As much as PITA as the wellnuts seem to be at first, if you just tighten them up loose-snug, they do their job perfectly.
RE: front fender
06/26/10 1:16 AM
Hey Rook...ya...I never have any probs with mine...except they wear out and the threaded end comes off!BTW....I meant to ask ya...how's that "schooling" goin with the Hub man.Hope yer learnin a lot a good stuff.He IS still workin with ya,like he said isn't he? (okay,I know,I'm SUCH an asshole!)All in fun bro...all in fun.Ride safe!
* Last updated by: blue07 on 6/26/2010 @ 1:17 AM *
